My Gladiator is making a thump or popping noise when turning steering wheel left or right
JK Spartan Adventures
Frank
Conway, AR
2017 Jeep Wrangler Sport S, 2021 Jeep Gladiator
Senior Microsoft Systems Engineer
Hey Jeep Community,
My Gladiator has a thumping or popping noise when i turn my steering wheel left or right. It happens standing still or even when driving. Have you guys ran into this before?
Frank
Conway, AR
Its coming from the front end. I can hear it. If i have someone turning the steerin wheel and i am out under the jeep. It is coming from the front end. I just cannot pin point on where it is coming from. I think it might be the drag link. However, i am not for sure.
High Alextude
Alex
Maryland
2022 Jeep Gladiator Overland High Altitude
I’m not sure what you’ve done to your Jeep thus far, but I would check track bar ends and make sure all lug nuts are tight.
Frank
Conway, AR
I have a 3.5 lift from rough country. I replaced the front track bar that comes with that kit with the steer smarts front track bar. I added the steer smarts sector shaft brace. This kit has been on my Gladiator for about 5 months. I have tighten down the components every 3000 miles since the first tight down after 500 and 1000 miles. This popping and/or thumping just started about a week ago.
Lunentucker
2021 Jeep Gladiator Mojave
People Work?
If it's clunking it should also be sending a vibration through the related components.
If possible, get someone to work the steering while you hold a hand on each steering component and see if you can feel it to source if out.
Obvious precautions to prevent injury or death.
Jeep Gladiator My Gladiator is making a thump or popping noise when turning steering wheel left or right monty-python-holy-grail
Frank
Conway, AR
Thanks, i will do that tomorrow.
bleda2002
2021 JTR Firecracker Red
Ball joints, check the torque on the ball joints as they will click if loose
Caspien
StLouis, USA
2025 1500 RAM, 2020 GC Trailhawk, (Previously 2021 JTR)
I.T. Architect
I'm going to propose a simple solution (since I just had the same thing happen, today.. lol), may not be the problem, but figured I'd at least offer up a potentially easy problem that can cause a pop when turning the wheel.
Have you checked your inner fender liners? After washing mine today, I started noticing a popping noise.
Turns out, when I used the pressure washer to clean all of the mud and rock from the liners, I actually pulled 2 of the plastic panel retainers free, which caused the liner to sag a bit... and when turning the wheel, it'd snag a bit. Replaced the 2 retainers, issue resolved :)
(I seriously hope your issue is this one, since it's less than a dollar :)
~ Casp
Frank
Conway, AR
Thank you! I fixed it this morning. I got under the Gladiator and had the wife move the steering wheel back and forth and it turn out being the pinch bolt on the drag link not being tightin down and i did that all is good no more popping or thumping going on drove it around for about 30 minutes. Steering is good.
Elgin
Elgin
Boston
2023 Jeep Gladiator Rubicon
I have the same issue. How did you notice the pinch bolt on the drag link not being tightened? By looking or touching?
Camaroboi13
SoCal
LEO - Life in Chino
Sometimes it’s hard to see, best to grab the bar and see if you can feel it moving. On a side note I had a clunking issue and I thought it was the track bar. Turns out my steering box was falling off the Jeep ?
